Cisco Prime how to hide SSID
Thomas Park
Hi there.
I need to hide SSID from broadcast from Cisco Prime.
I can do this easily on WLC by un-checking 'broadcast' under SSID on WLC but I have controller which I only have access through Cisco Prime.
So I would like to find out how I can disable broadcast on Cisco Prime please.
Thanks in advance
Scott Fella
Create a (Controller) template for WLAN's and you can apply the template to a specific controller that is associated to PI.
-Scott
-Scott
Saurav Lodh
Level 7
Level 7
Refer : creating / adding templates
http://www.cisco.com/c/en/us/td/docs/wireless/prime_infrastructure/1-3/configuration/guide/pi_13_cg/temp.html#20699
