Cisco Prime Infrastructure Manager 1.3 and HP Switches
JuergenDietl_2
I am on setting up the Cisco Prime Infrastructure Manager 1.3. I have 2 issues with 3rd party switches.
Cisco says that they full support LLDP for any device but I get this error with HP-Procurve when I do a discover:
feature_lldp_neighborsSNMP request timed out
LLDP is on of course.
Also Cisco says that they support all RFC1213 MIBs. So I put in some of the MIBs but I didnt get any results.
Any ideas? Any one succeded in this 2 things?
Your help would be much appreciated.
thanx a lot and have anice weekend.
cheers,
Juergen
8 Replies 8
Scott Fella
I really don't think their wireless devices support LLDP as it doesn't state that in the data sheet.
-Scott
I didnt talk about wireless.
As I was told Cisco Prime Infrastructure Manager 1.3 is the summary of Cisco LMS 4.2 and the LMS WIreless.
So it should support both. But yes you are true when I look into the product it seems that it is 70 % wireless tool and they forgot to put in most from LMS.
So my question again for wired switches.
thanx a lot,
cheers,
Juergen
There are some Cisco switches that are not fully yet supported. So that should give you info that not all devices are yet supported. You might have to ask your Cisco SE regarding LLDP as it is mentioned here in the supported device list.
http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/1.3/supported/devices/cpi13_supported_devices.xlsx
-Scott
Hello Scott,
thanx for your answer but the question was only for 3rd Party product like HP.
Statement from Cisco:
• Ability to discover and monitor third-party (non-Cisco) switches that support RFC
1213 and wireless controllers/access points from Aruba Networks.
But except the reachability I dont see anything.
cheers,
Juergen
I think they are trying to support more of the wireless for now.  The ability to discover... well I guess the ability isn't there yet.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
maybe its my English sorry.
I speak of
* 3rd Party  (like HP)
* NON WIRELESS switches
So this question is not answered. But I asked now Cisco for a statement.
As a Cisco Smartnet Owner I have some support. When I know some news I will post here.
regards,
Juergen
Scott Fella
I understand it is switches... Why its not supported right now, well LMS isn't really 100% migrated to PI. What I'm saying is that PI has more support for wireless than non wireless devices at the moment. If you have concerns about this, you need to ask your Cisco SE. They can provide you with more info.
-Scott
s.hellman
Hi Juergen.
Did you get any more info about this?
