cisco prime report bandwidth utilization by ssid per location
redrobish
Hi All,
Anyone knows how to generate a report from Prime 2.2 with bandwidth utilization by ssid per location? Basically I wanted to see per location how much BW is my wifi using on per month period.
Tried everything but not giving me any good report
inarp
We had to use solarwinds & customize reporting to pull these kinds of stats per SSID.
I've been hoping to find this feature in Prime 3.2 - Still nothing. The closest thing I can find is enabling AVC on the controller, but even that is kind of sketchy.
We have multiple SSID's on 1 AP and would like to know bandwidth used on a particular SSID.
Feature request maybe?
In Prime 3.2, isn't that available under Dashboard - Performance - Site?
Under Network Aware select Wireless and then the SSID.
Please note, in my case all those Dashlets are empty, but maybe they do work for you. Based on the wording, I think those are the ones you want.
For this to work you'll need to send netflow data from the WLC to the Prime.
