Cisco Prime SSH Issue
ittechk4u1
Level 7
Level 7
Hello Experts,
I can access Cisco Prime vai GUI and Console access but not via SSH.
Connecting to <IP>:22 (press Esc to cancel)...
[SSH] FAIL: <IP>:22 - No connection could be made because the target machine actively refused it.
What could be the reason!
Thanks in advance.
7 Replies 7
Mark Elsen
 - Through console access issue the command , ncs status , check if no problems are reported.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
All services are running....
- Make sure your client is not hampered by a local firewall and or try from another platform/os to verify this.
 M.
Or simply issue a reboot command on the CLI, maybe the daemon crashed.
i tried that thrice..still no ssh posible.
I have to install and restore it again.
Can you check if ssh is correctly enabled?
For this, open the CLI and enter 'show running'
You should see several lines, important are a correct set gateway, there should be a username be configured with the role admin and the command 'service sshd'.
For example:
interface GigabitEthernet 0
ip address 172.16.20.12 255.255.255.0
ipv6 address autoconfig
ip default-gateway 172.16.20.1
clock timezone CET
ntp server ch.pool.ntp.org
username admin password hash jdlkajfdölahfshafdöah role admin
service sshd
It didn't work.
I had to install new one and restore the backup.
Thanks for help.
