cisco switch 2960 error disable issue
KAMAL MISHRA
Dear Team,
i have an issue i have two cisco 2960 switches both are connected with each other but in one switch one of my port is going on error disable after some time .
here i am attaching my conf of both switches
problem is at switch 244 on port gi 1/0/20
2 Accepted Solutions
Rasika Nayanajith
Once your port get error disabled, get this output & post it here
show interfaces status err-disabled
Rasika
**** Pls rate all useful responses ****
kaaftab
Level 4
Level 4
Do share the out of the command and if possible the log from the switch.
and use the command # error-disable recovery to recover
5 Replies 5
luckymike33
can you post the output from the followng command from switch 244.
show log
show int status
show run int gi1/0/20
Very best wishes
Mike
Rasika Nayanajith
Rasika
Dear Sir,
i have make the port no shut and reconfigure that switch its on under observation.
kaaftab
Level 4
Level 4
thaks kaaftab
