Cisco vWLC vs Cisco Mobility express controller
Asfandyar70754
Level 4
Level 4
 Hey guys,
So one of my client is looking to deploy wireless infra in their environment, so they have ordered Cisco WLC appliance and Access point 9k series, now the APs have been delivered but WLC isn't delivered yet, but he wanted wireless up and running soon so I was wondering what is the better option Cisco vWLC or Mobility Express controller bearing in mind that the WLC appliance is to be delivered in couple of months.
5 Replies 5
It depends on how many and which APs you have. With under 50 APs I would probably go for the EWC (this is what was Mobility Express on the x800 series). If you have more APs I would probably go for the virtual WLC.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Rich R
NO @Karsten Iwen !!!!   ME and vWLC are both legacy AireOS based solutions approaching end of life so that would be a backward move! Correction I see you already mentioned EWC instead of ME 🙂
@Asfandyar70754 You already have Catalyst 9000 series APs although you don't mention which model(s).  Those can run EWC on AP which is the modern equivalent of ME based on 9800 series IOS-XE and much better than ME.  Supports up to 100 APs (depending which model of AP you run it on).
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/nb-o6-embded-wrls-cont-ds-cte-en.html
https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/white-paper-c11-743398.html
https://www.cisco.com/c/en/us/support/docs/wireless/embedded-wireless-controller-on-catalyst-access-points/215303-embedded-wireless-controller-conversion.html
If you need to support more than 100 APs then you can use 9800-CL virtual controller.
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-cl-wireless-controller-cloud/nb-06-cat9800-cl-cloud-wirel-data-sheet-ctp-en.html
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
@Rich R (Correction, I see you already read again ... 🙂 🙂) please read again, using EWC is exactly what I suggested. And with the APs being of the Catalyst 9100 series it is clear that we are not talking about AireOS any more. Same for the vWLC, with that I was talking about the 9800 virtual controller. Regardless which 9800 hardware controller model was ordered, *no* Cisco partner would "sell" a legacy vWLC when the hardware controller is delayed to speed up the deployment.
Rich R
@Karsten Iwen I had already updated my reply noting your reference to EWC.
vWLC is the product name of the AireOS product so you need to be clear when recommending a product to anyone reading who may not realise you were referring to 9800-CL which is the new product name.
I have not expected any confusion here and I do not think that the OP is talking about an AirOS product, but instead of the type of device. And at least here the term vWLC is also used for the class of products of virtual WLCs. But you are right, with being a little more specific I could have avoided any confusion what I typically try to achieve. I'll promise to do better in the future (or the next beer is on me if I do that again ...).
