cisco VWLC with external captive portal https://192.0.2.1/login.html?redirect error
Recently I try to configure a cisco virtual cisco WLC with clearpass. So I have created a guest SSID and when a client connects to it  he is successfully redirected  to clearpass self signed portal. There the user can self register himself and he receives the receipt from clearpass. When I press the "Login" button to continue further then I receive in the browser the address https://192.0.2.1/login.html?redirect and I cannot continue. In addition I cannot see any radius messages from access tracker to arrive at the clearpass.
The problem is not for sure in the radius configuration of the cisco wlc because I have another wlan connection "corporate ssid", where I use 802.1.x for authentication and I receive radius messages. Anybody has any idea what may be the cause of this problem?
Rasika Nayanajith
Pls check this document and ensure you follow the given guidelines.
https://www.cisco.com/c/en/us/support/docs/wireless/flex-7500-series-wireless-controllers/113605-ewa-flex-guide-00.html
Rasika
*** Pls rate all useful responses ***
