Cisco wireless access points for Warehouse
farispv
Dear Cisco Community,
I would like to inquire, what will best suitable wireless access points for warehouses where has lot racks.
inside the factory.
Scott Fella
If you will search the forum, what you will find is not a straight forward answer, because a site survey is required to guarantee coverage. Ap height, density of product, roaming, scanning areas, are all variables to ensure you have a solid wireless deployment. Doesn’t matter what access point you have if the coverage is not there.
-Scott
Scott Fella
-Scott
Leo Laohoo
There is only one suitable answer for this:  If you want to get this done right, then get a wireless site survey done correctly.
