Wireless Mobility
henokk601
Level 2
Level 2
Hi All
I start configuring cisco 3800 accesspoint i already configure the first one. first i install ME software on the access point and now it act as a controller what is the next step inorder to join the other APs in the controller. Do i have to install Mobility Express software on the rest APs i dint get the cisco confg guide useful at all please any help?
Leo Laohoo
Enable DHCP option 43 so the APs can find the ME.
Scott Fella
Rasika Nayanajith
You do not other APs in ME mode (just leave it CAPWAP mode unless your order them with ME image). For simple verification, if you put all these AP on the same subnet as your ME AP, then they should go & register to your WLC running on ME AP
Rasika
