07-21-2016 02:19 AM - edited 07-05-2021 05:28 AM
Does anybody know how to check on MSE or on PI regarding how many licenses used by wIPS module? Kit list and software version as under;
Currently can't find any where to see "these many licenses consumed by wIPS modules". On MSE dashboard its showing "Active APs - 148" on the floor maps. all services and devices fully sync with each other. Identical on PI as well.
Also, does ELM option on AP configuration page only available on PI interface or should it also be seen on WLC>AP page too?
Many thanks.
Syed
Solved! Go to Solution.
07-21-2016 09:36 AM
Syed,
The only way I know you can find this information is buying consoling into the MSE. Maybe one of these days they will add this to the GUI.
Follow these steps in order to check the wIPS license usage:
1. Log in to the MSE CLI and enter the cd/opt/mse/wips/bin command in order to navigate to the wIPS directory.
2. Enter the ./wips_cli command.
3. When you get into wIPS mode, enter the show ap summary command.
I hope this helps.
David
07-21-2016 09:36 AM
Syed,
I hope this helps.
David
07-22-2016 04:28 AM
Many thanks David. Much appreciated. It worked.
