Cisco Wireless Anchor Controller
Hello Team,
I would like to know how wireless Anchor Controller works and the configuration guidelines.
Ethelbert
Scott Fella
I would suggest you take a look at the various guides and blogs that are out there and explain guest anchor. You will also find the guides to the setup, that is the best place to look. Search “Cisco WLC guest anchor design"
-Scott
