Cisco Wireless AP
jelikinto83
Community Member
Good day,
I’ve been using an old Ruckus wireless AP. It’s served me well however the device is no longer supported i.e no further firmware updates.
The AP is for a small office with few users. Any recommendations on a Cisco AP? Something simple will do. Reliability and stability are the requirements here.
Thanks.
balaji.bandi
here is the small business mode of AP - since we do not know what model you used - its hard to tell and compare with out knowing model of existing.
Cisco  SMB
https://www.cisco.com/c/en_uk/solutions/small-business/networking/wireless.html
if you looking more look for Meraki also. ( you get lot more with less cost)
https://meraki.cisco.com/en-uk/products/wi-fi/
BB
There are two product lines I wood look at:
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
