Cisco Wireless Controller License Upgrade
rakesh nair
Currently my WLC having capacity of 80 and i need to add more AP's to that. For that i am having one product Key and license. I need to know howm many more Ap's i can add to the WLC with this License. My product name is L-LIC-CT5508-UPG
Product Name : L-LIC-CT5508-UPG
Product Description: Primary SKU for CT5508 upgrade licenses
Sandeep Choudhary
Hi Rakesh,
5508 WLC can support max of 500AP. So if you have currently 80 AP license installed on it then you can add 420 more AP license on it.
You can buy any of these:
L-LIC-CT5508-5A
L-LIC-CT5508-25A
L-LIC-CT5508-50A
L-LIC-CT5508-100A
L-LIC-CT5508-250A
Don't forget to rate helpful posts
8 Replies 8
Sandeep Choudhary
Hi Rakesh,
L-LIC-CT5508-5A
L-LIC-CT5508-25A
L-LIC-CT5508-50A
L-LIC-CT5508-100A
L-LIC-CT5508-250A
Hi Sandeep,
          We have purchased L-LIC-CT5508-UPG this one
Rakesh,
check the Table 5 of this document:
http://www.cisco.com/c/en/us/products/collateral/wireless/5500-series-wireless-controllers/data_sheet_c78-521631.html
Rergards
I saw that table and there it mentioned like this. Is it mean we can add total 420 APs
L-LIC-CT5508-UPG
Primary upgrade SKU: Pick any number or combination of the following options under this SKU to upgrade one or many controllers under one product authorization key
CON-SNT-LCTUPG
Yes, But you need to order adder license in combination of these(multiple of 5):
L-LIC-CT5508-5A
L-LIC-CT5508-25A
L-LIC-CT5508-50A
L-LIC-CT5508-100A
L-LIC-CT5508-250A
Okay, so u mean UPG license is the base one and we need to purchase adder license also. So how we are uploading the license, only the adder license or both UPG and adder
Hi Rakesh,
You just need to buy adder license in combination of above 5 , which i mentioned in my last post.
only adder license can be added to cisco WLC.
Hello Dear,
 We are adding this ( L-LIC-CT5508-5A ) APs license but unfortunately this is not showing on CCW. So how to add?
