Cisco wireless EAP-TLS authentication issues
David.Pellat
Level 2
Level 2
We have setup a new wireless environment and were looking at using EAP-TLS. This works ok, but no matter what we do it will never prompt for username and password credentials as well as the mutual certificate authentication. Is there a way that this can occur? We are using:
Cisco WLC 7.2
CISCO ACS 5.2
MICROSOFT SERVER 2008 AD infrastructure
Windows 7 PC
Any info or articles greatly appreciated
Kind regards
David
Scott Fella
EAP TLS just uses a certificate on the client machine for authentication. Peap uses credentials for authentication. You can't use both.
-Scott
Amjad Abdullah
EAP-TLS does not prompt for credentials. It uses the clients certificates to provide client's identity.
You need to read EAP-TLS deployment guide, it is interesting and useful: http://tiny.cc/l27ojw
Amjad
You want to say "Thank you"?
Don't. Just rate the useful answers,
that is more useful than "Thank you".
Rating useful replies is more useful than saying "Thank you"
