cisco wireless hotspot2.0 trial (Passpoint)
Mohamed Sayed
Hi all,
I configure the pass point (hotspot2.0) and i need the CA certificate to add it on the "cred.conf" which will be added to my handser (Samsung note 4) to be able to join the hotspot 2.0
please advice
Saurav Lodh
Level 7
Level 7
1. Same as Method 3, an external editor is used to create the config file. Save the file name as "cred.conf".
2. Copy the file to an external memory card (microSD Card).
3. Insert the microSD card to the phone device.
4. Run the "My files" application.
5. Navigate to /extSdCard and confirm if the "cred.conf" file is available (copied into the external memory card at step 2).
6. Long key press "cred.conf" file until the Copy menu is displayed.
7. Select "Copy" and paste the file to the parent folder /sdcard0.
If Passpoint system is configured for EAP-TLS, CA certificate and User certificate must be copied using microSD card. The files can also be sent as emails because PKCS#12 SGS4 support multiple certificate encoding formats. ".p12" formatted certificate is generally recommended.
Refer:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-5/Hotspot_057.html
hi salodh,
thanks for your support,
I need to know from what i can get the ca_cert ?
thanks
