02-17-2016 12:24 PM - edited 07-05-2021 04:37 AM
Does anyone have experience with a Netgear WNCE3001 connecting to a cisco wireless network? Specifically, Cisco 5760 controllers and cisco 3700i access points. I am unable to get one of the devices to connect, even to our guest which has no security. TIA
02-17-2016 01:15 PM
If you can't connect to an SSID with no security configured I don't think there is anything that is going to work.
02-20-2016 07:04 AM
Let's not narrow it down to just a netgear device. Does anyone know of any issues with using a NON-CISCO WGB with cisco 5760 controllers? TIA
02-21-2016 11:06 AM
Workground bridge attachments between different vendors is fraught with issues. On the whole, it never works.
02-21-2016 02:06 PM
Do you have specific knowledge of the interoperability between NON-CISCO WGB and cisco 5760 controllers?
02-21-2016 02:09 PM
I don't have specific knowledge.
WGB's were not really "standardised" like normal WiFi clients. Hence vendors created them all different kinds of ways. As a result, you often can't mix them between vendors.
I would be surprised if you got it working.
