Cisco Wireless with AzureAD
mumbles202
Level 7
Level 7
Currently have a working controller with AD integration using a onsite Radius server.  Active Directory is Hybrid w/ AzureAD at this point and the goal is to move fully to AzureAD in the near future, but I haven't found a good workaround for the inability to have NPS in the cloud.  I've seen some third party software that can act as the NPS server and sit between the WLC and AzureAD.  Looking to get some feedback on what others have done possibly and see what is working for other users.  Currently the controller is a 2504.
Scott Fella
I don't think Microsoft is supporting NPS any longer which tells me that they probably will not have an offering in Azure.  You would need to look at something like Cisco ISE that can support AzureAD and can also be stood up in Azure.
-Scott
mumbles202
Level 7
Level 7
Thanks for the feedback.  I had started to look a possible doing ISE with SAML to AzureAD as a solution.  I'll keep that open as an option.
