Cisco Wireless with multiple ssid's
raikone14
Today I started deploy a cisco 1602 autonomous, but the client asked me to configure two different ssid's. I did,two different ssid's and two different vlans. My question is, should this access point operate in bridge mode ? I will connect this device in my firewall interface.If yes, how is the bridge configuration on a cisco autonomous ap ?On my firewall I did two sub-interfaces one for each vlan.
thank you guys...
Rasika Nayanajith
No, You do not want to configure it as bridge. Sample AP config look like below. As long as you connect it to a port configured as trunk (something similar in FW) it should work.
hostname AP-01
dot11 ssid <SSID1>
   vlan 10
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii <SSID1_PASSWORD>
dot11 ssid <SSID2>
   vlan 20
   authentication open
   mbssid guest-mode
   wpa-psk ascii <SSID2_PASSWORD>
interface Dot11Radio0
 encryption vlan 10 mode ciphers aes-ccm
 encryption vlan 20 mode ciphers aes-ccm
 mbssid
 ssid SSID1
 ssid SSID2
 no shut
interface Dot11Radio1
 channel width 40-above
 mbssid
 ssid SSID1
 ssid SSID2
 no shut
interface Dot11Radio0.10
 encapsulation dot1Q 10
 bridge-group 10
interface Dot11Radio0.20
 encapsulation dot1Q 20
 bridge-group 20
 encapsulation dot1Q 1 native
 bridge-group 1
interface Dot11Radio1.10
 bridge-group 10
interface Dot11Radio1.20
 bridge-group 20
 bridge-group 1
interface GigabitEthernet0.10
 bridge-group 10
interface GigabitEthernet0.20
 bridge-group 20
 bridge-group 1
interface BVI1
 ip address 192.168.1.2 255.255.255.0
ip default-gateway 192.168.1.1
Rasika
*** Pls rate all useful responses ***
Than you.
My configuration looks like yours.
But I won't connect to a switch, I will connect to a firewall, with sub-interfaces, and each sub-interface has an ip.
So I can't have a default gateway.
Why bridge mode doesn't work ?
Thank you again for your help.
