07-11-2017 09:35 AM - edited 07-05-2021 07:19 AM
Hi Folks,
I have a network of 12 APs - 5 x 3702i, 4 x 1532, and 3 x 1552H - all connected to a 2504 WLC.
I've successfully configured the 2504, the 3702s and the 1530s - but I'm having a problem with the 1552H's.
I've tried all three, and the same thing happens with each of them - when they start up only the uplink light goes green - all of the others (RF1,RF2 and status) stay black. I can console into them fine, but they don't appear to be even trying to connect to the WLC. I've already entered their MAC addresses in Security > AAA > MAC Filtering - but as far as I can see they're not even attempting to contact the WLC, let alone join it.
Each of them is powered by a 1500 series power injector, which plugs into the same switch that the WLC is on.
Can anyone suggest any troubleshooting steps please?
Regards, Lee.
Solved! Go to Solution.
07-12-2017 02:01 AM
Yes k9w7 means your AP are using autonomous image:
https://rscciew.wordpress.com/2014/01/04/understand-access-point-ios-images/
First convert form autonomous to CAPWAP. and then try again to Join
How to convert:
https://www.youtube.com/watch?v=Fiv76UpStKI
http://www.networkoc.net/converting-stand-alone-cisco-autonomous-access-point-to-lightweight-access-point/
Dont forget to rate helpful posts
07-11-2017 03:11 PM
Post the complete output to the following commands:
07-12-2017 01:54 AM
Hi There,
Thanks for your response - I've attached the requested output.
Maybe the ap show version provides a clue - judging by the version info: System image file is "flash:/c1520-k9w7-mx.153-3.JC1/c1520-k9w7-xx.153-3.JC1" - am I right in thinking the AP has been sent to me in autonomous mode?
Regards, Lee.
07-12-2017 02:01 AM
How to convert:
07-13-2017 05:40 AM
Hi Sandeep,
Yeah figured that managed to get them changed over this morning - thanks for all your help.
Regards, Lee,
