Cisco Wireless
nipul.sawant
Community Member
Hello Team,
Need help to configure Wireless Network. i have 2702E autonomous - (8unit) with SG300-28port (1 Unit).
Requirement :-
1. Multiple SSID with different VLAN on AP.
2. WDS or Repeater mode for WL.
Nipul
Rasika Nayanajith
Here is a sample config required on AP. Switch port you need to configure as trunk and native vlan on the same as AP managment (999 in below example)
hostname AP-01
dot11 ssid SSID-1
vlan 1
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii <SSID_1_PASSWORD>
dot11 ssid SSID-2
vlan 2
authentication open
mbssid guest-mode
wpa-psk ascii <SSID_2_PASSWORD>
dot11 ssid SSID-3
vlan 3
authentication open
mbssid guest-mode
wpa-psk ascii <SSID_3_PASSWORD>
interface Dot11Radio0
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 2 mode ciphers aes-ccm
encryption vlan 3 mode ciphers aes-ccm
mbssid
ssid SSID-1
ssid SSID-2
ssid SSID-3
no shut
interface Dot11Radio1
channel width 40-above
mbssid
ssid SSID-1
ssid SSID-2
ssid SSID-3
no shut
interface Dot11Radio0.1
encapsulation dot1Q 1
bridge-group 10
interface Dot11Radio0.2
encapsulation dot1Q 2
bridge-group 20
interface Dot11Radio0.3
encapsulation dot1Q 3
bridge-group 30
interface Dot11Radio0.999
encapsulation dot1Q 999 native
bridge-group 1
interface Dot11Radio1.1
bridge-group 10
interface Dot11Radio1.2
bridge-group 20
interface Dot11Radio1.3
bridge-group 30
interface Dot11Radio1.999
bridge-group 1
interface GigabitEthernet0.1
bridge-group 10
interface GigabitEthernet0.2
bridge-group 20
interface GigabitEthernet0.3
bridge-group 30
interface GigabitEthernet0.999
bridge-group 1
interface BVI1
ip address 192.168.99.101 255.255.255.0
ip default-gateway 192.168.99.1
end
write memory
Rasika
*** Pls rate all useful responses ***
