Disable broadcasts globally on WLC and enable it per access point / SSID
Hi Fellows,
I'm searching for a solution to disable the Ethernet broadcast setting on the WLC globally and enable it only on a per access point / Vlan basis.
Is there any way to achieve this? Maybe through FlexConnect?
I was not able to find any related documentation that would cover this problem.
Feedback / Input is highly appreciated.
Christian
Not possible, it is a global setting and no recommend to enable this feature if you have a large wireless environment.
Rasika
*** Pls rate all useful responses ***
