Cisco Wireless
cristomike2
Community Member
At my company we are currently using a Cisco WLC 5508 to manage our wireless network across 2 dozen+ office locations across the US and Canada.
We're starting to run up against the license limit of WAP's on the current controller. We're in the process of adding another (at least) dozen sites to our infrastructure, with 1-4 AP's per site. After looking at the cost to purchase additional seats on the controller we've begun looking at other options for our wireless needs.
Has anyone here run into this issue? And what was your solution? Did you pony up the cash for the additional seats on the WLC? I have trouble fathoming managing 75 WAP's without a single pane of glass to control them..
Leo Laohoo
Have a look at Mobility Express/eWLC. This turns an AP into a mini-WLC while still functioning as an AP.
But be aware that eWLC requires DNA licensing for each AP so analyse and compare the costs carefully. From https://www.cisco.com/c/dam/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/q-and-a-c67-743152.pdf
What are the licensing requirements for the Embedded Wireless Controller?
Cisco Catalyst 9100 Access Points bought with the EWC software will have Cisco DNA term-based licensing.
Do I need Smart Account for EWC? Yes, a Smart Account is required for an EWC deployment.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
