cisco wireless
Anjana A
Level 4
Level 4
Hello team,
we are using cisco 5520 wlc with 8.10.130.0 ios.
AP model is 3702 ap, users are reporting slowness in wifi. while checking the interference found thrid party interfering devices for 802.11b radio.
Almost all users are getting connected to 802.11ac/802.11n radios, whether the interference on 2.4 radio will cause slowness for this users.
AP04
 Persistent Interference Devices
  Class Type                 Channel  DC (%%)  RSSI (dBm)  Last Update Time
  Canopy                     6        1       -82         Thu May  6 21:02:34 2021
  WiMax Fixed                1        0       -62
                             6        0       -62         Mon May 10 04:52:17 2021
  All third party trademarks are the property of their respective owners.
Ap05:
  Microwave Oven             11       9       -74         Wed May 12 03:30:32 2021
  Canopy                     11       1       -86         Mon May 10 06:22:26 2021
AP06
  Video Camera               1        100     -73         Sun May  9 22:06:43 2021
Anjana
9 Replies 9
saravlak
No, interference on 2.4ghz band shouldn't impact 5ghz users.
if the reported users are from 5ghz then the issue is something else that needs to be narrowed down and isolated.
Leo Laohoo
Not enough info:
  1. What band were the users connected to, 2.4 Ghz or 5.0 Ghz?
  2. What OS were the users on?  Are they ALL using the same OS?
  3. What happens when you transfer data from one wireless client to another wireless client?
  1. What band were the users connected to, 2.4 Ghz or 5.0 Ghz?  users are connected to 5.0 GHZ
  2. What OS were the users on?  Are they ALL using the same OS?  Yeah all users are same OS .OS Windows10
  3. What happens when you transfer data from one wireless client to another wireless client? they are facing slowness.
Try using different OS:  Try with Android/Chrome, Apple iOS.
And how many users are connected to the radio/AP? What is the configured channel width on the 5 GHz radio and how high is the radio utilization?
We have totally 6 AP's at site. All the users connecting to the AP are facing the slowness irrespective of the ssid.
Regards, Anjana
And how many users are that?
Is this slowness new or was it always there?
Could you maybe run an iperf between a wireless connected and a lan connected user?
Have you tried rebooting one AP and test if it's ok again for that one AP?
I agree with patoberli.... you need to start trying to isolate the issue and gather as much information as you can.  If you believe it is that one ap, swap that ap with another that has no issues and see what happens.  Basic troubleshooting in wireless is to reproduce the issue and gather the facts.  Try different devices, check nic firmware, etc.  This way folks here can help you resolve the issue or provide feedback that may help.
-Scott
saravlak
need granular issue statement and more detailed scenario/use-case -Wireless slow is a very generic statement, the generic stuff to check.
Any recent change in network - config/setup/upgrades.
are issues isolated within LAN/WAN network, Does WAN link have enough bandwidth.
Any physical port errors noticed. are port speed/duplex configs fine.
Are all or specific applications impacted. is it tcp/udp/multicast traffic impacted.
what's the expected speed and how much are you getting.
And talk to end-user to obtain feedback to understand the exact issue.
