cisco wirelless controller Ap problem
Hiko
Level 3
Level 3
Hi Friends
 I have more Cisco Ap(Air-Cap-2702 E-E-K9 int my company everthing is ok but i have 2 problem
1) When some user connect to specialy one AP  these users after 2-3 minute disconnect from wifi what is reason? 2.4Ghz and 5GHZ is active . i think AP is not right working .
2) My internet speed is 200mps but only this Ap speed is 2-3mps i check with  speedtest.com . can be physcial problem ?
Lets start by rebooting it. If that doesn't help, replace the LAN cable, maybe the cable is broken. If it's attached to a manageable switch, check the interface statistics for increasing errors.
10 Replies 10
Rasika Nayanajith
Are they running Autonomous mode ? or are these AP managed by a WLC
What power level these operate ?
Rasika
Ap working with Wirelles Controller .Poe Status PoE/Full Power ..
What antenna is installed on the AP? How many of the antennas?
What is the height of the AP?
Hi Leo
before 1 month this AP working is good in same location but have problem now . height is normal i think is every configuration is normal.yesterday i change AP wit new AP now is new AP good working. can be physcial problem for old AP?
Hi patoberli.
1) i reboot but does not solve
2) When i check cable cable is good
3) when i change AP with new AP prolem solved but why i see some problem from old AP what is reason i dont know
Maybe the AP has a hardware defect. This can happen. Test it in your lab and if you can reproduce the issue, RMA it. You have 10 years of hardware warranty typically.
yeap i think hardware defect
Ok, this is a 2700, right?
Remote into the AP and post the complete output to the command "dir".
i think hardware defect because if was confgration problem too new app must not work but new app working good
