Cisco WLC 2504 additional APs liciense
hatterfix
Good day.
We have WLC 2504-15-K9 with pre-installed liecense for 15 APs
Now we need to increase number of supported APs up to 40.
So what type of liecense should we bought for this solution ? And whats the steps of liecense instalation on the WLC in that way ? Where I can find an actual guide ?
luis_cordova
Hi @hatterfix
You need to buy 1 "25 Access Point Adder License " if the WLC support 15 AP now plus 25, you can achieve 40 APs.
The  part number is "L-LIC-CT2504-25A" is you want to receive you license by email or "LIC-CT2504-25A" if your want to have a paper with the license.
Please check this link
Contact Cisco sales for more information.
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
*Tu reconocimiento nos alienta a seguir participando en los foros *
