cisco C1111-8PLTEEAWE Version 16.7.1 Help with Wifi Configuration.
Edward Elric
Hello
I'm writing here because I can't find a clear solution to the WI FI configuration of this product,
I don't know if I can publish the commands I use to enter the WI FI unit as "sh platform"
Chassis type:
C1111-8PLTEEAWE
Slot Type State Insert time (Aug) --------- ------------------- --------------------- - ---------------- 0 C1111-8PLTEEAWE ok 8w3d
0/0 C1111-2x1GE ok 8w3d
0/1 C1111-ES-8 ok 8w3d
0/2 C1111-LTE ok 8w3d
0/3 ISR-AP1100AC-E ok 8w3d
R0 C1111-8PLTEEAWE ok, activate 8w3d
F0 C1111-8PLTEEAWE ok, activate 8w3d
P0 PWR-12V ok 8w3d Slot CPLD Version Firmware Version --------- ------------------- ---------------------- -----------------
0 17100501 16.6 (1st)
R0 17100501 16.6 (1st)
F0 17100501 16.6 (1r) ",
I am new to this world and I would like to know if someone can
help me locate in which private IP the WI FI module is placed by the mac,
so I could find it in an ARP table with some MAC FINDER.
Sorry for bad english.
Have a good day.
5 Replies 5
patoberli
Here is the manual:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/wlan/configuration/xe-16-7/wl-16-7-book.html
Start at the first, then second link and so on :)
Thanks, that manual help me a lot, now i know the mac of the module is 0000.5e00.0101 always so i can find really fast now in witch Private IP it is. if this help someone the Name with https://macvendors.com/ is always same.
Now, when I do a NAT to go through a web page to the module, it doesn't always work, I don't know why, you could help me, I can't find that in the manual.
Greetings.
Not sure what you try to achieve. Do you try to configure a NAT on the router or are you using an external NAT?
Nat inside router Conf T, nat from loopback to a privete IP like 192.168.0.150 for example, 192.168.0.150 because we have the WI FI module in that IP, so when i put my Loopback on Firefox for example i can join in my Wifi module.
but not always works.
that is what im asking, if u can help me :(.
I have never configured such a router, but have a look here at the NAT configuration:
https://www.cisco.com/c/en/us/td/docs/routers/access/1100/software/configuration/xe-16-7/cisco_1100_series_swcfg_xe_16_7_x/cisco_1100_series_swcfg_chapter_01000.html
Otherwise please post the complete configuration (remove all passwords first).
