Cisco WLC 3504 login and configuration issue
abinaya.2.r
I have  one AIR-CT3504-K9.
There are two issues I am facing.
1. Due to a strange reason I am unable to Http/https the WLC.  I can telnet the WLC and tried config network webmode/secure web enable. rebooted the WLC. But no luck. can some help share your suggestion.
2. I wanted to configure an SSID as below
Layer 2 security WPA+WPA2
WPA Policy - Enabled
WPA Encryption :TKIP
WPA2 Policy - enabled
WPA2 Encryption -AES
Authentication Key management:
802.1x Enabled.
But when I configure the WPA, I get
(Cisco Controller) >config wlan security wpa wpa2 enable 2
ERROR: Invalid configuration for WLAN 2.
(Cisco Controller) >config wlan security wpa enable 2
Request Failed: Invalid security policy.
Scott Fella
Try to regenerate the certificate for management and then reboot the controller. As far as SSID, you should only use WPA2/AES. Using both causes issues with clients connecting.
-Scott
