Cisco WLC 3700 Performance Problem
Ben Duff
Level 2
Level 2
We have a Ubiquiti UAP-AC-PRO that we're testing, the performance of this is significantly better than a Cisco 3700 we have connected to a 5508 controller. On a file transfer we see the Ubiquiti perform twice as fast on two different 5Ghz clients, one with an older Intel 6205 (N) and one a 8260 (AC). APs are in the same location and I don't believe any enviromental issues are occurring. The connection speeds appear the same on the client when connected to the AP.
Our question is what configuration have we got wrong on the 3700/5508 as clearly something is wrong? On the controller the older 6205 client shows a connection speed of m7 and the newer 8260 shows m9 ss2, is this the problem? In Windows it shows a connection of 300/866.
Ben
16 Replies 16
Rasika Nayanajith
Pls share "show wlan <wlan_id>" & "show client detail <client_mac_add>" output from your 5508.
<wlan_id> is the ID number where your client associate to.
Rasika
See below, it's currently connected to another ap further away as I'm not in the office but config is same.
WLAN Identifier.................................. 2
Profile Name..................................... marist-secure
Network Name (SSID).............................. marist-wifi
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
    Radius Profiling ............................ Disabled
     DHCP ....................................... Disabled
     HTTP ....................................... Disabled
    Local Profiling ............................. Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
ATF Policy....................................... 0
Number of Active Clients......................... 2
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 86400 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 720 minutes
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... none
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ marist-client
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Tunnel Profile................................... Unconfigured
PMIPv6 Mobility Type............................. none
    PMIPv6 MAG Profile........................... Unconfigured
    PMIPv6 Default Realm......................... Unconfigured
    PMIPv6 NAI Type.............................. Hexadecimal
    PMIPv6 MAG location.......................... WLC
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
Scan Defer Priority..............................
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... 802.1P (Tag=0)
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ 192.168.2.12 1812 *
   Authentication................................ 192.168.2.11 1812 *
   Accounting.................................... Global Servers
      Interim Update............................. Enabled
      Interim Update Interval.................... 0
      Framed IPv6 Acct AVP ...................... Prefix
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Radius NAI-Realm................................. Disabled
Mu-Mimo.......................................... Enabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
      OSEN IE.................................... Disabled
      Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
         OSEN-1X................................. Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web Authentication Timeout.................... 300
   Web-Passthrough............................... Disabled
   Mac-auth-server............................... 0.0.0.0
   Web-portal-server............................. 0.0.0.0
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   FlexConnect Central Association............... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   flexconnect PPPoE pass-through................ Disabled
   flexconnect local-switching IP-source-guar.... Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Disabled
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
   Eap-params.................................... Disabled
AVC Visibilty.................................... Enabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Split Tunnel Configuration
    Split Tunnel................................. Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
802.11v Directed Multicast Service............... Disabled
802.11v BSS Max Idle Service..................... Enabled
802.11v BSS Transition Service................... Disabled
802.11v BSS Transition Disassoc Imminent......... Disabled
802.11v BSS Transition Disassoc Timer............ 200
802.11v BSS Transition OpRoam Disassoc Timer..... 40
DMS DB is empty
Band Select...................................... Enabled
Load Balancing................................... Client-Count Based
Multicast Buffer................................. Disabled
Universal Ap Admin............................... Disabled
 Mobility Anchor List
 WLAN ID     IP Address            Status                             Priority
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
Priority  Policy Name
Lync State ...................................... Disabled
Audio QoS Policy................................. Silver
Video QoS Policy................................. Silver
App-Share QoS Policy............................. Silver
File Transfer QoS Policy......................... Silver
Client MAC Address............................... e4:b3:18:1b:fa:08
Client Username ................................. host/E5470-11453
AP MAC Address................................... f8:c2:88:b1:d1:20
AP Name.......................................... ap11
AP radio slot Id................................. 1
Client State..................................... Associated
Client User Group................................ host/E5470-11453
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 2
Wireless LAN Network Name (SSID)................. marist-wifi
Wireless LAN Profile Name........................ marist-secure
Hotspot (802.11u)................................ Not Supported
BSSID............................................ f8:c2:88:b1:d1:2e
Connected For ................................... 339 secs
Channel.......................................... 100
IP Address....................................... 192.168.9.114
Gateway Address.................................. 192.168.8.1
Netmask.......................................... 255.255.254.0
IPv6 Address..................................... fe80::558d:81ea:b1c9:c37c
Association Id................................... 1
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
Client CCX version............................... 4
Client E2E version............................... 1
Re-Authentication Timeout........................ 86070
QoS Level........................................ Silver
Avg data Rate.................................... 0
Burst data Rate.................................. 0
Avg Real time data Rate.......................... 0
Burst Real Time data Rate........................ 0
802.1P Priority Tag.............................. disabled
CTS Security Group Tag........................... Not Applicable
KTS CAC Capability............................... No
Qos Map Capability............................... Yes
WMM Support...................................... Enabled
  APSD ACs.......................................  BK  BE  VI  VO
Current Rate..................................... m7 ss2
Supported Rates.................................. 12.0,24.0,36.0,48.0,54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Audit Session ID................................. c0a8040800000021577370b5
AAA Role Type.................................... none
Local Policy Applied............................. none
IPv4 ACL Name.................................... none
FlexConnect ACL Applied Status................... Unavailable
IPv4 ACL Applied Status.......................... Unavailable
IPv6 ACL Name.................................... none
IPv6 ACL Applied Status.......................... Unavailable
Layer2 ACL Name.................................. none
Layer2 ACL Applied Status........................ Unavailable
Client Type...................................... SimpleIP
No. of mDNS Services Advertised.................. 0
Policy Type...................................... WPA2
Authentication Key Management.................... 802.1x
Encryption Cipher................................ CCMP (AES)
Protected Management Frame ...................... No
Management Frame Protection...................... No
EAP Type......................................... EAP-TLS
VLAN............................................. 8
Quarantine VLAN.................................. 0
Access VLAN...................................... 8
Local Bridging VLAN.............................. 8
Client Capabilities:
      CF Pollable................................ Not implemented
      CF Poll Request............................ Not implemented
      Short Preamble............................. Not implemented
      PBCC....................................... Not implemented
      Channel Agility............................ Not implemented
      Listen Interval............................ 225
      Fast BSS Transition........................ Not implemented
      11v BSS Transition......................... Not implemented
Client Wifi Direct Capabilities:
      WFD capable................................ No
      Manged WFD capable......................... No
      Cross Connection Capable................... No
      Support Concurrent Operation............... No
Fast BSS Transition Details:
Client Statistics:
      Number of Bytes Received................... 605967
      Number of Bytes Sent....................... 255508
      Total Number of Bytes Sent................. 255508
      Total Number of Bytes Recv................. 605967
      Number of Bytes Sent (last 90s)............ 81060
      Number of Bytes Recv (last 90s)............ 352815
      Number of Packets Received................. 1238
      Number of Packets Sent..................... 819
      Number of Interim-Update Sent.............. 0
      Number of EAP Id Request Msg Timeouts...... 0
      Number of EAP Id Request Msg Failures...... 0
      Number of EAP Request Msg Timeouts......... 0
      Number of EAP Request Msg Failures......... 0
      Number of EAP Key Msg Timeouts............. 0
      Number of EAP Key Msg Failures............. 0
      Number of Data Retries..................... 545
      Number of RTS Retries...................... 0
      Number of Duplicate Received Packets....... 0
      Number of Decrypt Failed Packets........... 0
      Number of Mic Failured Packets............. 0
      Number of Mic Missing Packets.............. 0
      Number of RA Packets Dropped............... 0
      Number of Policy Errors.................... 0
      Radio Signal Strength Indicator............ -60 dBm
      Signal to Noise Ratio...................... 33 dB
Client Rate Limiting Statistics:
      Number of Data Packets Received............ 0
      Number of Data Rx Packets Dropped.......... 0
      Number of Data Bytes Received.............. 0
      Number of Data Rx Bytes Dropped............ 0
      Number of Realtime Packets Received........ 0
      Number of Realtime Rx Packets Dropped...... 0
      Number of Realtime Bytes Received.......... 0
      Number of Realtime Rx Bytes Dropped........ 0
      Number of Data Packets Sent................ 0
      Number of Data Tx Packets Dropped.......... 0
      Number of Data Bytes Sent.................. 0
      Number of Data Tx Bytes Dropped............ 0
      Number of Realtime Packets Sent............ 0
      Number of Realtime Tx Packets Dropped...... 0
      Number of Realtime Bytes Sent.............. 0
      Number of Realtime Tx Bytes Dropped........ 0
Nearby AP Statistics:
      ap11(slot 0)
        antenna0: 67 secs ago.................... -82 dBm
        antenna1: 67 secs ago.................... -65 dBm
      ap11(slot 1)
        antenna0: 66 secs ago.................... -73 dBm
        antenna1: 66 secs ago.................... -63 dBm
DNS Server details:
      DNS server IP ............................. 192.168.2.11
      DNS server IP ............................. 196.128.2.12
Assisted Roaming Prediction List details:
 Client Dhcp Required:     False
Allowed (URL)IP Addresses
AVC Profile Name: ............................... none
Thanks for this input
As you can see above, client got MCS7 & got 2 spacial stream. This equals to 650Mbps data rate if you use 80MHz channel width.
If you see below chart (taken from Andrew's blog), your require SNR of 35 to achieve MCS8 which is the next higher data rate. Since your client get SNR of 33, this is the highest rate you can get.
Other thing I would check it those two different AP's power level & channel they operate. I noticed given AP operate in CH100.
Rasika
*** Pls rate all useful responses ***
Below is the same client connected to the closer AP, both APs are on the same desk as the client, one AP powered at a time. The Ubiquiti has a file transfer speed twice that of the 3700, not sure why it's so different? Any other settings that could be limiting it?
AP MAC Address................................... f8:c2:88:92:34:d0
AP Name.......................................... ap10
Wireless LAN Id.................................. 1
BSSID............................................ f8:c2:88:92:34:df
Connected For ................................... 187 secs
Channel.......................................... 64
Gateway Address.................................. Unknown
Netmask.......................................... Unknown
Association Id................................... 2
Re-Authentication Timeout........................ 86218
Current Rate..................................... m8 ss2
Supported Rates.................................. 6.0,9.0,18.0,24.0,36.0,48.0,
    ............................................. 54.0
Audit Session ID................................. c0a804050000002f57744516
FlexConnect Data Switching....................... Central
FlexConnect Dhcp Status.......................... Central
FlexConnect Vlan Based Central Switching......... No
FlexConnect Authentication....................... Central
FlexConnect Central Association.................. No
Client Statistics:
      Number of Bytes Received................... 8950456
      Number of Bytes Sent....................... 4188432146
      Total Number of Bytes Sent................. 4188432146
      Total Number of Bytes Recv................. 8950456
      Number of Bytes Sent (last 90s)............ -993116185
      Number of Bytes Recv (last 90s)............ 6957188
      Number of Packets Received................. 143169
      Number of Packets Sent..................... 2759436
      Number of Data Retries..................... 707
      Number of Duplicate Received Packets....... 27
      Radio Signal Strength Indicator............ -36 dBm
      Signal to Noise Ratio...................... 57 dB
      ap62(slot 0)
        antenna0: 21 secs ago.................... -88 dBm
        antenna1: 21 secs ago.................... -83 dBm
      ap62(slot 1)
        antenna0: 271 secs ago................... -86 dBm
        antenna1: 271 secs ago................... -88 dBm
      ap09(slot 0)
        antenna0: 21 secs ago.................... -90 dBm
        antenna1: 21 secs ago.................... -91 dBm
      ap48(slot 0)
        antenna0: 179 secs ago................... -93 dBm
        antenna1: 179 secs ago................... -91 dBm
      ap48(slot 2)
        antenna0: 452 secs ago................... -86 dBm
        antenna1: 452 secs ago................... -87 dBm
      ap06(slot 0)
        antenna0: 21 secs ago.................... -93 dBm
        antenna1: 21 secs ago.................... -89 dBm
      ap10(slot 0)
        antenna0: 21 secs ago.................... -35 dBm
        antenna1: 21 secs ago.................... -27 dBm
      ap10(slot 1)
        antenna0: 19 secs ago.................... -39 dBm
        antenna1: 19 secs ago.................... -47 dBm
      ap11(slot 0)
        antenna0: 21 secs ago.................... -83 dBm
        antenna1: 21 secs ago.................... -63 dBm
      ap11(slot 1)
        antenna0: 19 secs ago.................... -71 dBm
        antenna1: 19 secs ago.................... -62 dBm
DNS Server details:
      DNS server IP ............................. 0.0.0.0
Alright, I've converted the 3700 to autonomous and can get the same speeds now. So what could be wrong with the controller configuration that would be halving the speeds?
Hi Ben,
So what is the file transfer speed you get with Autonomous AP ? What is the value you get with 5508 ? How long this file transfer occurs (longer the better)
You can test it with FlexConnect AP mode & see what speed you get. Also try some other way of testing (iperf,etc) prior to come to a conclusion.
Rasika
We've had the same 3700 AP with both the autonomous and lightweight images. In autonomous we get 25-30MB/s transfer speeds with a N client, we get 50-60MB/s with an AC client, this is copying a 5GB ISO in Windows. The same AP and clients when connected to the controller see the speeds halved, about 12MB/s (N) and 33-36MB/s (AC).
I think it's a configuration setting just not sure what, the same speeds apply connecting to different WLANs configured on the controller.
I did try Flexconnect and didn't seem to make a difference, is there a way to confirm it's operating in Flexconnect?
Ben
In FlexConnect mode, you need to change AP mode from Local to FlexConnect & configure your WLAN for FlexConnect Local Switching. AP connected switchport should be trunk port and native vlan should be on AP management vlan. Refer below guide for detail explanation.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-5/Flex_7500_DG.html
Since traffic terminate on your local switch (not go to WLC), I would expect same speed as autonomous. Pls test this and see
Rasika
FlexConnect is enabled on the AP, the WLAN has FlexConnect Local Switching enabled and the switchport has been reconfigured and we're seeing the same speeds.
Is there some other setting under wireless on the WLC that could affect this?
Ben
In FlexConnect mode, traffic does not go to WLC. so if you think there is something on WLC contributing to this slowness, then you should see the issue with Local mode & not seen with FlexConnect local switching.
Since, you have configured those settings that need for MCS rates (802.1X with WMM enable), I do not think any configuration issues.
You can test with open SSID (without any security), if you think those encryption could cause this.
Also I would test with different software code on controller ? what is the current software version you use ?
Are you running any of this TAC recommended code on your 5508 ?
http://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-TAC-Recommended-AireOS.html
Rasika
Bug, https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuz32677 maybe, we're running 8.2.111.0. It's not resolved in FlexConnect though.
Yes, it could be this.
Did you raise a TAC case for this ?
Will log a case, running iperf currently, only getting 149Mbits/sec on 8.2.111.0 in both local and flexconnect, will downgrade and report.
Ben
We've downgraded to 8.0.133.0, the problem still exists when in Local mode, when we switch to FlexConnect it resolves the problem. We've upgraded back to 8.2.111.0 and the issue occurs both on Local and FlexConnect.
This could be a bug?
Local
FlexConnect
Ben
