Cisco WLC 5508 DHCP issues
JDMJeffy84
Hello guys,Need some assistance on DHCP settings.
We currently have 2 DHCP settings on our controller.
we have 1 Vlan Corporate which points to our Internal DHCP Server and the other GUEST we point it to our controller to serve out IP Addresses.
Issue we have is if the option in:Controller/Advanced/DHCP:
Enable DHCP proxy is ticked  - it stops Corporate clients getting IP Address - fails to 169.254.x.x and Guest clients can happily get IP Address from DHCP from the controller. If the DHCP Proxy is unticked it's vice versa.
Any ideas?
2 Accepted Solutions
DHCP option 82 is a king of enhancement specifically employed for distributed DHCP/relay enviornments.
Using this option, relays insert specific information to the request, for to get an idea of clients physical point of attachment or first interaction to the network.
Here is one good blog post i could find,
http://blog.ine.com/2009/07/22/understanding-dhcp-option-82/
Sahil
Here is a good video:
http://www.youtube.com/watch?v=xs3_Udm9Ipo
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
8 Replies 8
Scott Fella
DHCP proxy is required if you have a DCHP scope configured on the WLC.  DHCP Proxy should not affect your corporate users as long as dhcp is not being handled by an ASA or a dhcp server that doesn't like the dhcp request coming from a proxy.
Scott
-Scott
Ok if that needs to be enabled then my current setup is affecting corporate ><
If I debug dhcp message on controller I get the following messages:
DHCP Forwarding DHCP packet (332 octets)                      -- packet received on direct-connect port requires forwarding to external DHCP server. Next-hop is 192.168.x.x (= default gateway)
Seems to me it's not contacting the Internal DHCP server?
What dhcp server are you using for corporate... Microsoft?
Scott
-Scott
Is the DHCP server on the same subnet as the client, or is it on your 'management/server' VLAN?
Per best practices, it is not recommended to have a server on a dynamic interface.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Yes it's on Microsoft 2008 R2
DHCP server is on a seperate subnet (server VLAN)
Corporate on a different subnet 192.168.255.0 but has an IP helper address on L3 switch to get to DHCP
Management subnet for controller & APs on 192.168.222.0
Stephen: reading your old post: https://supportforums.cisco.com/thread/2139441
Mgmt via wireless is enabled
Oh think I've solved it!
Under Controller/Advanced/DHCP
I've set DHCP Option 82 Remote Id field format from AP-MAC to AP-ETHMAC.
I can now get IP Address for corporate and guest. Not sure whta that option does but it's worked?
Any suggestions?
Many Thanks
Sahil
Scott
-Scott
