Cisco WLC 9800 CL firmware downgrade
Cheah Lit Thor
Hi Expert,
I'm using WLC 9800 CL and i recently downgrade the firmware from 17.5.1 to 17.3.3 due to some voice traffic keep having call quality issue, after i downgrade the firmware to 17.3.3 solve my problem then i found after few days(not sure exactly when it happened) the WLC firmware automatically revert back to 17.5.1, may i know why it behave like this?
Before i downgrade the firmware to 17.3.3 i did deleted the unused files in the flash and only did the downgrade.
Appreciate some one can share with me any step i miss out ?
2 Accepted Solutions
Rasika Nayanajith
I hope you did it via GUI.
Did you commit your changes after the downgrade? if not it may roll back to previous firmware versions (with default 6-8hr auto abort).
Here is the CLI command to run once you upload the image to flash (assuming 17.3.4 is the code)
c9800#install add file bootflash:C9800-CL-universalk9.17.03.04.SPA.bin activate commit
Rasika
*** Pls rate all useful responses ***
Yes, that is the way.
10 Replies 10
Arshad Safrulla
Is you IOS-XE installed in install mode or bundle mode?
Please post the output for the below
  • show run | include boot
  • show boot
  • dir
Once i get the output then will send it here Thanks.
Leo Laohoo
Is there a DNAC appliance?
Nope just vWLC it self alone.Thanks
Rasika Nayanajith
Rasika
Yes i did it via GUI, am i still need to commit it after the upgrade although using GUI?
Yes, usually once 9800 reload, you will have to go there & commit your upgrade via GUI. Otherwise, it will roll back after timer expires (i think 6hr by default)
Rasika
Do you mean after I'm upload and install the new firmware through GUI then it will reboot, after it come back then i have to go to the software management to click commit?
Please post the complete output to the command "sh log on uptime".
