Cisco WLC 9800 map vlan to ssid
Calin Cristea
I have a WLC9800 (OS 17.9.3) configured as new with the minisetup from the beggining of configuration.
I want to use 2 subnets:
192.168.10.0/24 (vlan 10) for management
192.168.20.0/24 (vlan 20) for users
At first setup, i have configured the ip192.168.10.10 for the controller and a basic SSID called test
I want to map the test SSID with vlan 20.
I have looked up, and on configuration/SVI i have nothing. Also on VLAN i have nothing (by default)
Interface vlan is setup on the firewall, and i want to keep it like this.
So what i did was:
1. Configuration /Vlan, i have created Vlan 20 , name Users
2. I made a new flex profile, where i put native vlan 10 (management), and in Vlan tab i have added vlan 20 with the name of guest vlan
3. I have made a new policy, in Access Policies menu/Vlan, i have selected the vlan name
4. I have created a new tag,where i have mapped the ssid with the policy profile
5. Create the test wlan
6. On each access point, i have setup the new policy name, site
7. On each switch, i have transported vlan 10 and 20 , on the port where the AP is connected i have setup on trunk mode with native vlan 10.
For those who made a similar setup, please tell me if i need to do something else.
I don`t want to use the advanced setup.
Rasika Nayanajith
Pls have a look at this post, it may give you an idea where you have missed a step. In 9800, those tags & profiles are the way to configure any features for AP including WLANs
https://mrncciew.com/2023/01/21/9800-flexconnect-basics/
Rasika
*** Pls rate all useful responses ***
Rich R
And check your config with the output of "show tech wireless" using https://cway.cisco.com/wireless-config-analyzer/
