Cisco WLC Customize Lobby Ambassador
ivan.martin
Hi my name is Ivan
Is possible to customized the web portal lobby ambassador?. Is possible to change the view or load another web page. I use authentication web in layer 3, and I would like to customize this portal ambassador
How can I do it?
Thanks for your answer
Scott Fella
There is no option to customize the lobby admin portal. Don't know if that will be available in future releases or not.
-Scott
Is possible to find any solution to customize the web page of lobby ambassador?
Ivan
You will not be able to unless you build a back-end that does it and sends the commands to the WLC. Other than that, you can't customize the lobby ambassador page.
-Scott
BRYN JONES
Is the page you want to customise the one wheer a user logs in using a temporary username and password or the one used by the adminstrators to log in and create the usernames?
