Aironet 1142 problems
youssef abdalla
Dear all,
i have 14 aironet 1142 work as atounomous
but i found this events  in syslog said that and i dunno if this is a big problem:
ios crypto fips self test passed
int g0/1 , change state to up
int dot radio 0 , change sate to up
but i don't undersatnd how it can change state to up without being an event for being down ?
and  sometimes i found that the interface dot radio is down , so why the dot radio interfaces goes down ?
7 Replies 7
George Stefanick
Not sure I understand .. Both of those tell us these are up. What seems to the problem ?
these events are detected and i need to understand it, that's it.
but sometimes on some access point i found that  the interface dot radio is down and dunno what is this happening
Can you please post the output to the command "sh version".  Please post the COMPLETE output as I want to see multiple items.
youssef abdalla
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 18:09 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
SMH-AP-1st-01 uptime is 5 days, 18 hours, 11 minutes
System restarted at 18:34:42 +0200 Tue Oct 16 2012
System image file is "flash:/c1140-k9w7-mx.124-21a.JA1/c1140-k9w7-mx.124-21a.JA1"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1141N-E-K9     (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1602W2R7
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
1 Gigabit Ethernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: C4:64:13:2B:F5:DC
Part Number                          : 73-12836-04
PCA Assembly Number                  : 800-33767-04
PCA Revision Number                  : A0
PCB Serial Number                    : FOC15502JSK
Top Assembly Part Number             : 800-33776-03
Top Assembly Serial Number           : FCZ1602W2R7
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1141N-E-K9
Configuration register is 0xF
That's an old IOS.  Try upgrading the IOS.
Can you also post the "sh logs"?  I want to see the events before and after the radios go down/up.
i don't have the logs before and after but i m monitoing it now , when it will be down i will post the logs.
from where i can get the new IOS version ? do i have to contact cisco or buy it or what ?
You need to have a valid Cisco Service Contract to be able to download firmwares.
