05-21-2015 02:27 PM - edited 07-05-2021 03:17 AM
i would like to configure wired guest acces with wlc 5508 (release 7.6.130), but when i set Guest lan on interface (vlan wired) the system remove the ip address configuration. I don't understand what device should act as the default gateway. Who can explain me in detail this function ? My client receive ip address before contact wlc and don't reside directly on the vlan wired.
05-21-2015 04:10 PM
This doc should explain how this feature works & configuration required
Rasika
*** Pls rate all useful responses ***
05-21-2015 05:20 PM
check the dhcp proxy settings, def. gateway on egress
Refer: https://supportforums.cisco.com/discussion/11528601/wlc-5508-getting-confused-while-setting-guest-lan
and
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/99470-config-wiredguest-00.html#anc5
05-22-2015 03:18 AM
Wired guest access enables guest users to connect to the guest access network from a wired Ethernet connection designated and configured for guest access. Wired guest access ports might be available in a guest office or through specific ports in a conference room. Like wireless guest user accounts, wired guest access ports are added to the network using the lobby ambassador feature.
Wired guest access can be configured in a standalone configuration or in a dual-controller configuration that uses both an anchor controller and a foreign controller. This latter configuration is used to further isolate wired guest access traffic but is not required for deployment of wired guest access.
Wired guest access ports initially terminate on a Layer 2 access switch or switch port configured with VLAN interfaces for wired guest access traffic. The wired guest traffic is then trunked from the access switch to a controller. This controller is configured with an interface that is mapped to a wired guest access VLAN on the access switch.
