Problem installing certificate .pem to WLC4404
Hi, im having several problems trying to upload my auth certificate to WLC. I tried upload to WLC but im having a error "ERROR INSTALLING CERTIFICATE"
I have seen this link. Which it seems interesting to me but i cant access.. can someone tell me how to access here?????
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsy88149
thanks
6 Replies 6
This is the error
TFTP Webauth cert transfer starting.
TFTP receive complete... Installing Certificate.
*TransferTask: Jan 22 16:50:28.849: sshpmAddWebauthCert: Extracting private key from webauth cert and using bundled pkcs12 password.
*TransferTask: Jan 22 16:50:30.800: sshpmDecodePrivateKey: calling ssh_skb_decode()...
*TransferTask: Jan 22 16:50:32.716: sshpmDecodePrivateKey: SshPrivateKeyPtr after skb_decode: 0x31afbb70
*TransferTask: Jan 22 16:50:32.717: sshpmAddWebauthCert: got private key; extracting certificate...
*TransferTask: Jan 22 16:50:32.723: sshpmAddWebauthCert: extracted binary cert; doing x509 decode
*TransferTask: Jan 22 16:50:32.724: sshpmAddWebauthCert: doing x509 decode for 1319 byte certificate...
Error installing certificate.
Jesus:
Do you follow this steps:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00806e367a.shtml
if you still with the problem contact me =)
Abhishek Abhishek
You can try using DER = The DER extension is used for binary DER encoded certificates. These files may also bear the CER or the CRT extension.
Saurav Lodh
Level 7
Level 7
similar issues :
https://supportforums.cisco.com/discussion/10811806/upload-pem-file-wlc
sobhardw
Please refer to the below Community :
mohanak
Chained certificate can not have Wildcard * character in hostname
CSCsy88149
Symptom:
Web-Auth client (user laptop) while trying to do web redirection receives the error " There is a problem with the website's security certificate", although redirection is successful and user is allowed access.
Conditions:
Wireless client doing Web Authentication using IE6, IE7 or Firefox web browser and the WLC using uploaded third party certificate having wildcard * in the Hostname.
Workaround:
Use of a Hostname in the certificate without the wildcard param *. eg. wifi.longueuil.ca instead of *.longueuil.ca
Further Problem Description:
Web Authentication for Internal Guest access on a Wireless LAN Controller running code 5.2.178.0. 3rd party certificate including a wildcard * in the Hostname uploaded it to the WLC. The WLC accepts the certificate without error. When a client running IE6, IE7 or Firefox connects to the Guest WLAN, it receives the error "There is a problem with the website's security certificate". If they choose to continue the web authentication works and the user is allowed access.
