04-25-2016 07:25 AM - edited 07-05-2021 04:56 AM
I am using Cisco WLC2504 controller with 3502i Access points. I would like to create 2 different SSIDs.
SSID-2.4: Just enable 2.4GHz radio on this SSID.
SSID-5.0: Just enable 5GHz radio on this SSID.
Does anyone know how to achieve this? I spent a lot of time on CCO, reading through documentation and poking around on the GUI but so far haven't figured it out.
Thanks in advance.
Solved! Go to Solution.
04-25-2016 11:46 AM
See below ..
04-25-2016 11:06 AM
This is very easy.
Under the SSID settings, you can specify what radio the SSID is to be broadcasted on.
04-25-2016 11:46 AM
See below ..
