03-29-2022 05:54 PM
I am trying to connect a Cisco 9120AX model AP to controller model 5520.
Software version of the Wireless Controller is 8.2.151
Software version of the Access Point is 8.10.130.0
Does the AP image needs to be the same as controller ?
Vish
Solved! Go to Solution.
03-29-2022 06:06 PM
Upgrade the WLC to 8.10.X.X.
03-29-2022 06:06 PM
04-03-2022 06:34 PM
Thanks Leo, upgraded the IOS on the controller to 8.10 and the AP worked
04-22-2022 04:50 PM
How did the update goes?
Im in the current situation and need to upgrade.
From what my version is at, i will need to do a 2 step upgrade to 8.5.x then 8.10.x.
Are there any issues you encounter when doing the upgrade?
Did all AP came back with no issues?
03-30-2022 12:04 AM
- Check compatibility requirements here : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
M.
04-03-2022 06:35 PM
Thanks Marce.
