Clean Air Question
Peter Nugent
Ok so I understand CleanAir and its deploment however I am trying to get my hea around these scenarios.
If I deploy 3500 access points pervasivly and wanted to deploy monitor mode access points for wIDS would I just deploy 1142s as monitor aps for wIDS as I do not need a 3500 as an overlay as I have these deployed pervasively?
Is the 3500 incorporated into Spectrum Expert yet as I cannot find details?
Stephen Rodriguez
You could use a 1130/1242/1142 for Monitor mode AP, as they are not going to be servicing clients anyway.
As for 3500 to Spectrum Expert, yes it is/going to be integrated in the 4.x release of the software.  Not 100% sure on the release date, but should be soon.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Vinay Sharma
Level 8
Level 8
Hello Pete,
Please mark the Question as Answered, if the provided information by Stephen is correct and it helped. By doing that others can take benefit as well.
Vinay Sharma
Community Manager – Wireless
Thanks & Regards
