CLi command for wireless controller to determine total of 802.11b only clients
Steven Shelton
The customer's wireless controller is currently supplying service for 802.11b, 802.11g and 802.11bn.  Using the command line, is there a command which will provide the total of clients which associated using 802.11b only, not 802.11bn or g.  Thank you.
Scott Fella
You can issue a show client summary and then look for 802.11b devices from that.  You can capture that output and filter that on a text file or in excel also if you want.
-Scott
-Scott
Thanks Scott, that's exactly what I found too.  In this case, I'm working with several thousand clients and didn't know if there was an easier way.
Thanks again
You can paste the output into excel and then do a text to column then you can use filter for the column header to only show 802.11b
-Scott
-Scott
Abhishek Abhishek
This example shows how to display a summary of the active clients:
> show client summary
Number of Clients................................ 24
