How do you fix the association bugs that the 1510s have?
My problem is when a client (like a laptop) associates to the MAP (Mesh Access Point) or RAP (Rooftop Access Point), the client doesn't hand off it's wireless connection to the access point with the better signal strength. Is there a setting or configuration on the Wireless LAN Controller that would help this problem?
