Client authentication issue with large certificates
schulcz
Level 4
Level 4
Hi!
We have a strange issue. We use 9800-40 WLCs in HA-SSO deployment model. There is an WLAN network, clients authenticated by an external RADIUS server using certificates. If administrators use small certificate chains, authentication works perfectly. If they use longer chain, packets needs to be fragmented and authentication not works, packets don't arrive to the RADIUS server.
We did some packet capture on the client and saw that if they use the small certificate chain the fragments flag was set to 0. If they use the big certificate chain the fragments flag was set to 1 and the packet didn't reach RADIUS server.
What can be the problem, what should we check? Is that issue can be related to WLC configuration? Maybe related to capwap or MTU configuration?
Using small cert, auth works:
Using large cert, auth not works, packet don't arrive to RADIUS server:
Thanks!
8 Replies 8
Mark Elsen
 - @schulcz    Review this document : https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/222920-understand-radius-mtu-and-fragmentation.html
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
what is radius you use is it ISE ?
MHM
Saikat Nandy
In addition to what @Mark Elsen shared, you can have a look into CSCwo58100 as well.
@Saikat Nandy - Thank you for sharing that bug. It says it's fixed, but no releases are specified. Can you share information about which version(s) it's fixed in? Also does it affect all 17.12.x versions/service packs at least up to 17.12.4 APSP8, and will it affect local mode as well or specifically flex/central auth?
Yeah pretty much all the 17.12.x are affected. 17.12.6 where the fix has been added. APSP on top of 17.12.5 is in progress.
@Saikat Nandy Thank you! I forgot to ask, does it only occur in FlexConnect mode with central auth, or will local mode be affected also?
Yes..apparently that's what have been observed so far - Flex: central auth+local switching.
I would to share this doc from Cisco  explain some workaround to deal with fragment of radius frame
One workaround which I see solution for his issue is using specific source interface to connect to server instead of wmi which is defualt select by wlc.
This interface have mtu 1500 where wmi have less mtu than 1500 and this lead to fragment and drop of frame
Thanks for all
Have a nice day
MHM
