Client IP assignment SSID
athan1234
Level 8
Level 8
Dear all:
I need someone to explain this Client IP assignment L3 Romin to me.
I had a meraki migration before I copied the same SSID option L3 roaming, my clients stopped working they have internet access but they dont acces to internal resource from different vlan of the same meraki . When I changed from L3 roamin to local lan they begun to work and reach the internal server . Why do this behavor
aleabrahao
Meraki Community All-Star
Large WLAN networks (for example, those found on large campuses) may require IP session roaming at layer 3 to enable application and session persistence while a mobile client roams across multiple VLANs. For example, when a user on a VoIP call roams between APs on different VLANs without layer 3 roaming, the user's session will be interrupted as the external server must re-establish communication with the client's new IP address. During this time, a VoIP call will noticeably drop for several seconds, providing a degraded user experience. In smaller networks, it may be possible to configure a flat network by placing all APs on the same VLAN.
However, on large networks filled with thousands of devices, configuring a flat architecture with a single native VLAN may be an undesirable network topology from a best practices perspective; it may also be challenging to configure legacy setups to conform to this architecture. A turnkey solution designed to enable seamless roaming across VLANs is therefore highly desirable when configuring a complex campus topology. Using Meraki's secure auto-tunneling technology, layer 3 roaming can be enabled using a mobility concentrator, allowing for bridging across multiple VLANs in a seamless and scalable fashion.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
aleabrahao
aleabrahao
Also check on Firewall page configuration if the Local Lan is configured to allow access.
https://documentation.meraki.com/MR/Firewall_and_Traffic_Shaping/MR_Firewall_Rules
aleabrahao
If you want you can read It by yourself.
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/Best_Practice_Design_-_MR_Wireless/Wireless_Layer_3_Roaming_Best_Practices
