Client roaming issue between APs
MohamedNizamKN77297
Community Member
Dear Folks,
I have been facing an wireless Roaming Issue in our cisco Mobility express wireless controller. We used to Connect SSID (ISAP1) with Ipad's and will roam inside & Outside the Office. However, it seems to be the IPAD device is not getting connected automatically even it's very near to the access point.
When I turnoff and turn on the wireless settings, then it's getting connected. And It happens always.
As per the troubleshoot, I have upgraded the controller image. also enable the 2.5 & 5 Ghz band for this specific SSID. But the still the issue is same.
how can i sort out this issue. Can anyone advice
Rasika Nayanajith
Client roaming decision is purely made by the client. See below specific to iOS device
https://support.apple.com/en-au/HT203068
In your case where client does not trigger roaming, it could be due to different reasons. primarily conditions does not meet to trigger roaming decision. Could be your client hear both AP strongly and no reason for it to roam to next AP even you are next to 2nd AP.
I would check power levels (show advanced 802.11a summary for WLC CLI) & see if clients RSSI to see if that falls on those roaming conditions of apple client
Rasika
*** Pls rate all useful responses ***
See also:
https://support.apple.com/en-us/HT207308
https://www.cisco.com/c/dam/en/us/td/docs/wireless/controller/technotes/8-6/Enterprise_Best_Practices_for_iOS_devices_and_Mac_computers_on_Cisco_Wireless_LAN.pdf
https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2018/pdf/BRKEWN-2670.pdf
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-6/b_Cisco_Wireless_LAN_Controller_Configuration_Best_Practices.html?dtid=osscdc000283#concept_25B094B30CC84B65B817D5A19DE86D28
You don't mention what version you're using but it goes without saying that it should be up to date to avoid known bugs.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
