client roaming
Anjana A
Level 4
Level 4
Hello Team,
In our infra we are using 3800 & 9130(whih were newly deployed) AP's. Users while roaming between the access points facing disconnection.
for 9130 do we need to enable any specific settings for roaming? since both the access points are of different models, is it the reason for it?
WLC code - 8.10.151.0
WLC model - 5520
AP mode - Flex Conect
Anjana.
7 Replies 7
Mark Elsen
 - Make sure wireless coverage is good (usually achieved by wireless site survey) , clients (may) need updated drivers , : https://www.intel.com/content/www/us/en/download/19351/windows-10-and-windows-11-wi-fi-drivers-for-intel-wireless-adapters.html (e.g.). For the rest you can do client debugging on the controller and have these analyzed with : https://cway.cisco.com/wireless-debug-analyzer , you may also have the controller configuration checked by https://cway.cisco.com/tools/WirelessAnalyzer/ , for that it needs the output of show run-config with no prompts in between ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rasika Nayanajith
No specific setting on 9130 for roaming.
Did you test and verify if a client roam from 9130 to 9130 it does not have that experience ? You can "debug client {client_mac_add}" output and check any noticeable messages to give you some indication what's happening while client is roaming.
As a good practice, it is recommend not to mix different model of AP in the same area that could leads into problem like you described.
Rasika
*** Pls rate all useful responses ***
Rich R
- What type of WLAN authentication and what features enabled on the WLAN?
- Upgrade to latest version of code to eliminate known bugs - see TAC recommended link in my signature below.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
varma10
Level 3
Level 3
Were you able to find out the root cause or resolve this issue? I am also facing the same issue in my environment. I have mix of 9130's with 3802's attached to 9800-40 running on 17.3.6 code. I have noticed that the user (both MacBook and Windows) is re-authenticating in between 9130 WAPs even with 802.11r enabled.
I was able to resolve the issue after I disabled the Tri-band Radio on 9130 WAPs.
mmohammed
Level 2
Level 2
Hey Anjana,
Firstly different models of AP's are not suggested to be used in the same environment for obvious reasons. Apart from that roaming majorly depends on the client itself much more than the access points. Try updating the drivers and enabling fast roaming on devices to overcome this issue.
Hi Mohammed,
I did not have a mixed environment with AP models. My entire floor has 9130s installed, and I have fast roaming enabled as well. It has been continuously disconnecting the users. Tri-band Radio disablement helped me resolve the issue.
