Clients are not connecting to ssid
wyfy-2015
All the clients are not connecting ,If it is connected and suddenly disconnecting immediately in open area .
clients are  running .
channels are both 2.4 and 5
Increasing session timeout will help ?
Wlc shows the client ip address  assigned by dhcp, but the client does not show any ip address  assigned by dhcp
5 Replies 5
Leo Laohoo
Bad RSSI?
wyfy-2015
I checked the RSSI
Its good
@wyfy-2015 wrote:
I checked the RSSI
Its good
What is the RSSI value?
Rssi is -51
Use the command "debug client <MAC address>" and then get the machine to join the SSID. Post the output to the debug.
