ssid
narayana
Frequent Visitor
Frequent Visitor
How many ssid's will be supported by cisco 2802i access point
Mikey Boy
Level 6
Level 6
It's an open ended question. In theory lots, but generally don't go above 4 for lots of reasons related to channel utilisation.
All vendors generally recommend no more than four.
Sandeep Choudhary
As per my knowledge cisco AP's can only support up to 16, but the WLC you can configure more(by using AP Groups).
Cisco recommend max 3-4 in a wireless environment.  It's best practice.
Dont forget to rate helpful posts
Leo Laohoo
An AP can support up to 16 SSID.
If you have a "design" that requires an AP to broadcast 16 SSIDs then something is really, really wrong.
