Clients conneting AIR-CAP3702I-E-K9 slow speed for Internet
amit.gaur
Hello All,
Required help .
We have multiple access points at customer office .
Currently customer is only reporting issue for some access points .
Access point model is AIR-CAP3702I-E-K9 .
WLC model :AIR-CT5508-K9,
Current IOS:8.5.171.0
Symptoms : Teams “on hold”, Power BI slowness , downloading//uploading slow
Signal Status : full Bars
Radio Signal Strength Indicator............ -34 dBm
Signal to Noise Ratio...................... 53 dB
User detail
laptop model : Dell latitude 5400
driver latest : 20/10/2020 (updated to 21/06/2022)
transmit power : 5. Highest
roaming aggressiveness : 5. Highest
Regards/Amit
7 Replies 7
Leo Laohoo
These information is useless.
Post the complete output to the DOS command "netsh wlan show drivers".
(eff-e-rcc-wlc-1) >show client detail C8:CB:9E:0C:D0:7D
Client MAC Address............................... c8:cb:9e:0c:d0:7d
Client Username ................................. N/A
Hostname: .......................................
Device Type: .................................... Unclassified
AP MAC Address................................... b8:11:4b:b3:9c:c0
AP Name.......................................... rcc-fa-ap-03
AP radio slot Id................................. 1
Client State..................................... Associated
Client User Group................................
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 11
Wireless LAN Network Name (SSID)................. Mars-Protected6
Wireless LAN Profile Name........................ Mars-Protected6
Hotspot (802.11u)................................ Not Supported
BSSID............................................ b8:11:4b:b3:9c:c5
Connected For ................................... 2523 secs
Channel.......................................... 112
IP Address....................................... 10.26.28.138
Gateway Address.................................. 10.26.28.1
Netmask.......................................... 255.255.255.0
Association Id................................... 7
Authentication Algorithm......................... Open System
--More-- or (q)uit
Reason Code...................................... 1
Status Code...................................... 0
Session Timeout.................................. 0
Client CCX version............................... No CCX support
QoS Level........................................ Platinum
Avg data Rate.................................... 0
Burst data Rate.................................. 0
Avg Real time data Rate.......................... 0
Burst Real Time data Rate........................ 0
Avg Uplink data Rate............................. 0
Burst Uplink data Rate........................... 0
Avg Uplink Real time data Rate................... 0
Burst Uplink Real Time data Rate................. 0
802.1P Priority Tag.............................. disabled
Security Group Tag............................... Unknown(0)
KTS CAC Capability............................... No
Qos Map Capability............................... Yes
WMM Support...................................... Enabled
APSD ACs....................................... BK BE VI VO
Current Rate..................................... m9 ss2
Supported Rates.................................. 6.0,9.0,12.0,18.0,24.0,36.0,
............................................. 48.0,54.0
Mobility State................................... Local
--More-- or (q)uit
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Audit Session ID................................. 0a1a1d050000bbf563c9387c
AAA Role Type.................................... none
Local Policy Applied............................. none
IPv4 ACL Name.................................... none
AAA FlexConnect ACL Applied Status............... Unavailable
IPv4 ACL Applied Status.......................... Unavailable
IPv6 ACL Name.................................... none
IPv6 ACL Applied Status.......................... Unavailable
Layer2 ACL Name.................................. none
Layer2 ACL Applied Status........................ Unavailable
Client Type...................................... SimpleIP
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
No. of mDNS Services Advertised.................. 0
Policy Type...................................... WPA2
Authentication Key Management.................... PSK
Encryption Cipher................................ CCMP-128 (AES)
Protected Management Frame ...................... No
Management Frame Protection...................... No
EAP Type......................................... Unknown
--More-- or (q)uit
Interface........................................ data
VLAN............................................. 131
Quarantine VLAN.................................. 0
Access VLAN...................................... 131
Local Bridging VLAN.............................. 131
Client Capabilities:
CF Pollable................................ Not implemented
CF Poll Request............................ Not implemented
Short Preamble............................. Not implemented
PBCC....................................... Not implemented
Channel Agility............................ Not implemented
Listen Interval............................ 250
Fast BSS Transition........................ Not implemented
11v BSS Transition......................... Implemented
Client Wifi Direct Capabilities:
WFD capable................................ No
Manged WFD capable......................... No
Cross Connection Capable................... No
Support Concurrent Operation............... No
Fast BSS Transition Details:
DNS Server details:
DNS server IP ............................. 10.26.33.66
DNS server IP ............................. 10.26.33.120
--More-- or (q)uit
Assisted Roaming Prediction List details:
Client Dhcp Required: True
Allowed (URL)IP Addresses
AVC Profile Name: ............................... Voice and Video
OpenDns Profile Name: ........................... none
Fastlane Client: ................................ No
Max DSCP: ....................................... 46
Client Statistics:
Number of Bytes Received................... 28167207
Number of Bytes Sent....................... 125737691
Total Number of Bytes Sent................. 125737691
Total Number of Bytes Recv................. 28167207
Number of Bytes Sent (last 90s)............ 1327487
Number of Bytes Recv (last 90s)............ 515498
Number of Packets Received................. 96565
Number of Packets Sent..................... 204471
Number of Interim-Update Sent.............. 0
Number of EAP Id Request Msg Timeouts...... 0
Number of EAP Id Request Msg Failures...... 0
--More-- or (q)uit
Number of EAP Request Msg Timeouts......... 0
Number of EAP Request Msg Failures......... 0
Number of EAP Key Msg Timeouts............. 0
Number of EAP Key Msg Failures............. 0
Number of Data Retries..................... 33266
Number of RTS Retries...................... 0
Number of Duplicate Received Packets....... 8
Number of Decrypt Failed Packets........... 0
Number of Mic Failured Packets............. 0
Number of Mic Missing Packets.............. 0
Number of RA Packets Dropped............... 0
Number of Policy Errors.................... 0
Radio Signal Strength Indicator............ -37 dBm
Signal to Noise Ratio...................... 58 dB
Client RBACL Statistics:
Number of RBACL Allowed Packets............ 0
Number of RBACL Denied Packets............. 0
Client Rate Limiting Statistics:
Number of Data Packets Received............ 0
Number of Data Rx Packets Dropped.......... 0
Number of Data Bytes Received.............. 0
Number of Data Rx Bytes Dropped............ 0
Number of Realtime Packets Received........ 0
--More-- or (q)uit
Number of Realtime Rx Packets Dropped...... 0
Number of Realtime Bytes Received.......... 0
Number of Realtime Rx Bytes Dropped........ 0
Number of Data Packets Sent................ 0
Number of Data Tx Packets Dropped.......... 0
Number of Data Bytes Sent.................. 0
Number of Data Tx Bytes Dropped............ 0
Number of Realtime Packets Sent............ 0
Number of Realtime Tx Packets Dropped...... 0
Number of Realtime Bytes Sent.............. 0
Number of Realtime Tx Bytes Dropped........ 0
Nearby AP Statistics:
eff-e-rcc-ap-7(slot 0)
antenna0: 2525 secs ago.................. -67 dBm
antenna1: 2525 secs ago.................. -65 dBm
eff-e-rcc-ap-7(slot 1)
antenna0: 159 secs ago................... -74 dBm
antenna1: 159 secs ago................... -79 dBm
eff-e-rcc-ap-29(slot 0)
antenna0: 2525 secs ago.................. -74 dBm
antenna1: 2525 secs ago.................. -79 dBm
rcc-fa-ap-04(slot 0)
antenna0: 500 secs ago................... -87 dBm
--More-- or (q)uit
antenna1: 500 secs ago................... -87 dBm
rcc-fa-ap-02(slot 0)
antenna0: 500 secs ago................... -78 dBm
antenna1: 500 secs ago................... -78 dBm
rcc-fa-ap-02(slot 1)
antenna0: 499 secs ago................... -90 dBm
antenna1: 499 secs ago................... -90 dBm
rcc-fa-ap-01(slot 0)
antenna0: 500 secs ago................... -62 dBm
antenna1: 500 secs ago................... -62 dBm
rcc-fa-ap-01(slot 1)
antenna0: 500 secs ago................... -84 dBm
antenna1: 500 secs ago................... -84 dBm
rcc-fa-ap-06(slot 0)
antenna0: 500 secs ago................... -80 dBm
antenna1: 500 secs ago................... -80 dBm
rcc-fa-ap-06(slot 1)
antenna0: 155 secs ago................... -89 dBm
antenna1: 155 secs ago................... -89 dBm
eff-e-rcc-ap-28(slot 0)
antenna0: 2525 secs ago.................. -75 dBm
antenna1: 2525 secs ago.................. -71 dBm
eff-e-rcc-ap-28(slot 1)
(eff-e-rcc-wlc-1) >show client detail e60:F2:62:96:F0:CD
Incorrect input! Use 'show client detail <MAC addr>'
(eff-e-rcc-wlc-1) >show client detail 60:F2:62:96:F0:CD
Client MAC Address............................... 60:f2:62:96:f0:cd
AP MAC Address................................... 78:bc:1a:e4:9f:a0
AP Name.......................................... rcc-fa-ap-13
BSSID............................................ 78:bc:1a:e4:9f:a5
Connected For ................................... 10214 secs
Channel.......................................... 44
IP Address....................................... 10.26.28.150
Association Id................................... 53
--More-- or (q)uit
Client CCX version............................... 4
Client E2E version............................... 1
--More-- or (q)uit
Audit Session ID................................. 0a1a1d050000bb7363c906a0
--More-- or (q)uit
DNS Server details:
--More-- or (q)uit
Client Statistics:
Number of Bytes Received................... 163880825
Number of Bytes Sent....................... 267707917
Total Number of Bytes Sent................. 267707917
Total Number of Bytes Recv................. 163880825
Number of Bytes Sent (last 90s)............ 22171
Number of Bytes Recv (last 90s)............ 39577
Number of Packets Received................. 461077
Number of Packets Sent..................... 504743
--More-- or (q)uit
Number of Data Retries..................... 65497
Number of Duplicate Received Packets....... 376
Radio Signal Strength Indicator............ -42 dBm
Signal to Noise Ratio...................... 54 dB
--More-- or (q)uit
eff-e-rcc-ap-48(slot 0)
antenna0: 833 secs ago................... -63 dBm
antenna1: 833 secs ago................... -55 dBm
eff-e-rcc-ap-48(slot 1)
antenna0: 230 secs ago................... -60 dBm
antenna1: 230 secs ago................... -65 dBm
eff-e-rcc-ap-47(slot 0)
antenna0: 833 secs ago................... -51 dBm
antenna1: 833 secs ago................... -53 dBm
eff-e-rcc-ap-47(slot 1)
--More-- or (q)uit
antenna0: 230 secs ago................... -52 dBm
antenna1: 230 secs ago................... -58 dBm
rcc-fa-ap-11(slot 0)
antenna0: 5706 secs ago.................. -92 dBm
antenna1: 5706 secs ago.................. -92 dBm
eff-e-rcc-ap-46(slot 0)
antenna0: 15105 secs ago................. -72 dBm
antenna1: 15105 secs ago................. -73 dBm
rcc-fa-ap-13(slot 0)
antenna0: 230 secs ago................... -45 dBm
antenna1: 230 secs ago................... -45 dBm
rcc-fa-ap-13(slot 1)
antenna0: 230 secs ago................... -44 dBm
antenna1: 230 secs ago................... -44 dBm
rcc-fa-ap-12(slot 0)
antenna0: 231 secs ago................... -73 dBm
antenna1: 231 secs ago................... -73 dBm
rcc-fa-ap-12(slot 1)
antenna0: 230 secs ago................... -65 dBm
antenna0: 10571 secs ago................. -93 dBm
antenna1: 10571 secs ago................. -93 dBm
--More-- or (q)uit
rcc-fa-ap-05(slot 0)
antenna0: 10571 secs ago................. -89 dBm
antenna1: 10571 secs ago................. -89 dBm
eff-e-rcc-ap-57(slot 0)
antenna0: 15106 secs ago................. -62 dBm
antenna1: 15106 secs ago................. -64 dBm
eff-e-rcc-ap-57(slot 1)
antenna0: 16569 secs ago................. -74 dBm
antenna1: 16569 secs ago................. -83 dBm
Update the wireless NIC driver.  21.0.0.5 is an extremely old driver.
Intel 9560 Wireless Driver Download
And what about 22.150.1.1 version ?
The latest 9560 wireless NIC driver is 22.190.0.4.
Rich R
Both of those drivers are out of date - as Leo says 22.190.0.4 is latest for both:
https://www.intel.com/content/www/us/en/download/19351/windows-10-and-windows-11-wi-fi-drivers-for-intel-wireless-adapters.html
And you might want to update your WLC to 8.5.182.7 (link below) as well to eliminate any possible bugs in the WLC code that have been fixed since 8.5.171.0
Of course you're using WLC and APs which are end of software maintenance (approaching end of support) so any newly found bugs with these latest AX network adapters and drivers will not get fixed.
