Clients Disconnecting
GRANT3779
We aeem to have an issue where certain clients (looks only like win7) keep disconnecting from the WIFI. We have APs running in FlexConnect mode and registered to a remote controller. XP clients seem to be ok.
Anyone come across this, or know where to even start troubleshooting?
5 Replies 5
Scott Fella
Make sure you are using only one type of encryption. Either WPA/TKIP or WPA2/AES. Don't have both or a mixture of both. Also take a look at the client driver and make sure they have been upgraded to the latest.
-Scott
Hi Scott,
When you say encryption, where do I find these settings?
WLC GUI>WLAN>Select your SSID>Layer2 security>WPA & WPA2
WPA with TKIP
WPA2 with AES
and make sure to update your driver.
Also in the logs getting the following when clients are disconnected. I don't think it will be security related as it works on other sites which all use the same remote controller / SSIDs. Any ideas?
%DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client
%DOT1X-3-INVALID_REPLAY_CTR: 1x
What is your encryption your using. Post your show WLAN
-Scott
