Clients not able to join more 256 nos
searskarthik
We have using wireless controller CISCO 2125 with 8 nos LWAP 1252, including AP's getting the IP from windows DHCPserver (172.29.70.0/23), when clients reaches 256 nos in controller , then further not able to join in wireless network.
DHCP vendor class or user class will solve this issue. pl guide me .
thanks
Karthik
Nicolas Darchis
Hi Karthik,
the 2125 only supports 256 clients max. And anyway that amount of clients on 8 APs is already way too much.
Are you saying that no more clients can join after that ? or no more APs can join the WLC ?
Nicolas
Don't forget to rate answers that you find useful
Nicolas Darchis
Hi Karthik,
Nicolas
Hi Nicolas,
no more clients not able join in WLAN if exceeding 256.
thanks
Karthik
Well, it's totally expected then as it's the maximum amount of clients supported by the 2125.
If you have that amount of client you should look into having more APs and a more powerful WLC. That limit is not just there for marketing purpose. It looks like your network is under-powered compared to its real usage.
Nicolas
