Cisco wlc-Juniper Switch Compatability
maheshyerra
Can we deploy cisco WLC in juniper Switching LAN ( Juniper make Core switch and Access switch ) ? Any known issues on WLC 4400 behviour on Juniper Switching network.
Will CAPWAP protocol support b/w AP and Controller if we use juniper access switches and core switches.
Nicolas Darchis
A switch is a switch so there should not be an issue. If there is an issue, then one of the device (wlc or juniper switch) is not acting standard.
If you want to have LAG on the WLC, you need to check that Juniper supports eterchannels (no negotiation protocol) and src-dest-ip load balancing.
Nicolas
Don't forget to rate answers that you find useful
